Ok browsed the forum bout finding an actual organisation or individual that sells a r32 gtr grille
Im actually in Sydney NSW Australia
Thought buy now someone would be reproducing them by the mass with the amount of demand from the gtst boy's wanting to get rid of that ugly flat front, (reminds me so much of the gsl mistubishi cordiain appose to the gsr)
So here goes??
Is there a relyable source inwhich i could obtain a gtr grille from once i purchase my r32 skyline gtst??
Dont mind freight!!
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
