Mate Why are you selling
Keep the car it will be good for your soul
Especially in your current situation.
I am going thru the same thing and would be lost without my gtr
Avoid lawyers if you can they are devils in disguise
Be humble with the girl till its legally over you may get more.
Twenty years of female stealth control are over for me phewwwwwww
Shite buisness this divorce stuff
All the best mate and hope it works out for you. (make it happen)
Keep the car.
https://www.sau.com.au/forums/topic/183164-19000/#findComment-3321386
why dont u do a fake sale - give it to a trusting SAU member.....then once the divorce is finalised.....u take the car back. I think all you would have to do is just do the rego stuff etc....but its better than getting rid of something that you enjoy......
https://www.sau.com.au/forums/topic/183164-19000/#findComment-3321405
I don't know you but I agree whole heartedly with the above. Fake a sale, change the rego over to them (a mate) and once finalised get it back.
Unless you don't want the car anymore you'll regret doing this in spite of the mrs.
https://www.sau.com.au/forums/topic/183164-19000/#findComment-3321454
  • 3 weeks later...
    • No. Only for a standard ECU with/without Nistune. Standalone has no need for it. That's like the 3rd time I've said so.   And as to that sensor linked - yes, it does look like it would be the right one. I've never bothered to see how available they were - just assumed that they'd be hard to find. I think I'd be planning to go Link ECU rather than buy sensors I don't actually want to make Nistune work, if I did not already have Nistune. As you do not already have Nistune, you should realy consider your options.
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
