Mate Why are you selling
Keep the car it will be good for your soul
Especially in your current situation.
I am going thru the same thing and would be lost without my gtr
Avoid lawyers if you can they are devils in disguise
Be humble with the girl till its legally over you may get more.
Twenty years of female stealth control are over for me phewwwwwww
Shite buisness this divorce stuff
All the best mate and hope it works out for you. (make it happen)
Keep the car.
https://www.sau.com.au/forums/topic/183164-19000/#findComment-3321386
why dont u do a fake sale - give it to a trusting SAU member.....then once the divorce is finalised.....u take the car back. I think all you would have to do is just do the rego stuff etc....but its better than getting rid of something that you enjoy......
https://www.sau.com.au/forums/topic/183164-19000/#findComment-3321405
I don't know you but I agree whole heartedly with the above. Fake a sale, change the rego over to them (a mate) and once finalised get it back.
Unless you don't want the car anymore you'll regret doing this in spite of the mrs.
https://www.sau.com.au/forums/topic/183164-19000/#findComment-3321454
  • 3 weeks later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
