On my R33 Gts-t S2, I have just installed a FMIC, turbosmart BOV, and a turbosmart Dual stage boost controller. Apart from that my car is standard
on the low setting its wont go below 9psi. and on high it is 11psi
i want low to be &-8 psi but the tap wont go lower.
is this due to wrong installation or a boost creep
https://www.sau.com.au/forums/topic/183260-boost-problem/
I know.... i sorry if im not making any sense... but im not understanding it myself.
it was all working fine
but i got a cold air box from Unique sports .. and i need fit it in
and my dual stage controller is located near the air filter.
do i disconnected the hose and the negative wire . fit the box in and put the controller back in
now the boost levels are all over the place
https://www.sau.com.au/forums/topic/183260-boost-problem/#findComment-3322126
I can't help you if your answer to my question is 'The standard way'.
The vacuum hose from the controller should be connected to a T-piece. The T-piece should have an arrow on it. The arrow must point to the vac hose that connects to the actuator. The other side of the T-piece needs to connect to the pressure nipple on the intercooler piping that comes from the top of the turbo.
If you have it connected to the wrong nipple (there are 2) then it will not work. Also make sure you have disconnected the solenoid that is beside the power steer res.
https://www.sau.com.au/forums/topic/183260-boost-problem/#findComment-3322148
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
