cruise in nov
50 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hey Brett, I was the guy in the Silver R32 GTR from Narre North. I would be keen to go for a run up there, great drive for photos too.
Also if you and a few other people wanna go for a cruise one night send us a PM, i am always up for it.
sweetsweet! ill run the mt buller idea past a few people and if we can get a few numbers ill try to organise sumthin!
will do if we are ever gunna head out for a drive, same with you im allways keen to head down the beach for a spin wen the weather starts warming up!
cheers man
brett
will do mate, how ever i live in nsw now so maby xmas time when im back home we can go for a cruise.
also just got a email back from andre at ingition and he has to conferm dates but looks like it will be the 17th guys.
every one pray he can make it
hey guys yea im still up for this to however ignition haven't got back to me yet so i dear say we will no be looking at next year. ill kep you posted. just rember if this did go ahad it would be one big cruse and take time to orgonise
