Hey u goin guys planning on takin my skyline back 2 calder this fridai nite went last time with 3"inch turbo back and front mount air filter ( no heat shield or cold air induction) and a boost controller not EBC ran a 14.3 at 100.2 MPH now i dont know if thats shit or decent or wat for a r33 series 2 was hittin around 9-10psi , now ive got a greddy profec B spec II in and a full 90mm cold air innduction ran should i b looking for better times? if so roughly wat with decent take off and gear changes
https://www.sau.com.au/forums/topic/183800-14-mile-return/
what was your 60' time?
aroun 2.0 is good, 2.2 is average and can be improved upon.
without sounding slack, 14.3 is not a good time.
9-10 psi in a stock ECU'd r33 means it would be running pretty rich and on the edge of misfiring and carrying on.
cheapest way to get better times (apart from practice) is a tune with an SAFC to fix the air:fuel mixtures.
obviously some street legal drag radials.
then practice away.
maybe list any other mods.
what:
wheels and tyres and what size are they
what tyre pressure?
clutch
do you know what power it is making?
https://www.sau.com.au/forums/topic/183800-14-mile-return/#findComment-3328903
Hmm thinkn runnin back 2 standard boost on the nite , dunn have a clue power havnt had it tuned or dyno'd standard 16"inch wheels and standard clutch...like it hits around 7 then the boost slowly creeps up 2 around 9 on higher revs
2.303 60"
tyre pressure was around 28 psi for the nite from memory
https://www.sau.com.au/forums/topic/183800-14-mile-return/#findComment-3328912
just to give you a rough idea, my younger bro has a r33 gts-t series 1.5, stock turbo and engine, stock ecu (no SAFC), boost at 12psi, full exhaust, FMIC and a pod, pulled a 13.3 with a 2.0 60 foot time.
You should easily crack a high 13 with you mods if you launch it right and drive it hard.
https://www.sau.com.au/forums/topic/183800-14-mile-return/#findComment-3329349
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
