what happens is..
no acceleration..
hear turbo winding..
cant get over 2.5 revs or it starts jolting.. like its getting acceleration then loosing it quickly.
Does it 1/6 times i drive the car..
* When i bought the car it did this. He said it was a wiring problem on the AFM, wich it may be.. cause u play with the wiring and the car cuts off*
Just woundering what else this might be caused from if its not the wiring?
https://www.sau.com.au/forums/topic/183858-my-r32-gts-t/
what happens is..
no acceleration..
Hmmm.....sounds like limp home mode for a faulty AFM, won't let you rev past 2500rpm. My experience was exactly the same, happened fairly infrequently......at first. I killed mine thanks to the use of some normal silcon for a seal between the the AFM and the airfilter. The silcon was not "sensor safe". I know now better!
Cheers
https://www.sau.com.au/forums/topic/183858-my-r32-gts-t/#findComment-3330783
Is it auto or manual?
Sounds like your has blown a cooler piping. Check all the piping to make sure they haven't popped off, reason its surging above 2500rpm is because it builds boost, but the boost doesn't reach the intake manifold as it leaks out somewhere in the piping, then the car over fuels and start surging.
Thats my theory, check the simple things first.
If its not that, then chack AFM.
Abu
EDIT: Just re-read your post, does sound more like the AFM than anything. But check all things to be sure. :P
Edited by abu
https://www.sau.com.au/forums/topic/183858-my-r32-gts-t/#findComment-3330824
Try borrowing a friends afm and see if there's any difference. If it's not that, do what abu has suggested. Check piping.
Yep thats a good idea actually!
See if that works, saves you buying one and that not being the problem.
You could probably source a 2nd hand one from the forums for fairly cheap. Will keen an eye on the for sale section. If I see one I will post up the for sale thread link. :P
https://www.sau.com.au/forums/topic/183858-my-r32-gts-t/#findComment-3331018
thanks guys, yeah im pretty sure its the afm, i got a microtech to install when i get a new turbo.. so then i wont need my afm, just waiting on loom for the microtech, $300 is cheapest loom iv found so far... dont want to pay that much :nyaanyaa:
Yeah thats good. I reckon AFMs are more trouble then they are worth.
A MAP sensor would be much more reliable in that sense.
Well thats my personal opinion anyways lol
Edited by abu
https://www.sau.com.au/forums/topic/183858-my-r32-gts-t/#findComment-3333250
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
