Hey people,
I'm about to purchase myself a set of front and rear R33 calipers/discs, and from what I understand the R33 uses a BM50 as opposed to the R32 (current calipers and master cylinder) being a BM44.
So my question is, does the BM50 fit the same as S13/A31/R32 master cylinders, if not is it as simple as borrowing a pair of tube benders? Or would it require custom brakes lines? Or is there an alternative (Z32 brake master?) that will fit with no modification?
Or are people just using the R32 BM44 with their R33 brakes?
thanks.
https://www.sau.com.au/forums/topic/184081-master-cylinder-for-r33-brakes/
From what I understand R33GTST requires bending of the brake lines to fit, I don't know how much bending (I can use a pair tube benders if I need to, but I don't want to have to get new custom lines made up)
And I was thinking R32 GTR, but weren't they all equipped with ABS? (Master cylinders only have 2 outlets for ABS)
If 32GTR came out without ABS then I think that would be the brake master to get.
- i used a r32 gtst master cylinder bm44 ...it is exactly the same 3 outlet design all in the same position and is a straight bolt on ...hard to find though all wreckers didnt have one except for pick and payless and it was on a r30 but it was the only r30 that had one. The rest like the r31's use a pbr brand master.
- The r33's use a 2 outlet one (abs) still a bm44 though from memory. Same with s14's (did they all come standard with abs?)
- I think the gtr uses bm 50(r32gtr) or 57(r33gtr) which i think is 2 outlet.
- Nissan pintara FWD U12 uses a bm44, 4 outlet design. It has similar sized brakes to a stock turbo cefiro.
At the moment I'm using a BM44 with the R32 calipers, I guess I'll just have to wait until I have the R33 calipers on then make a decision about whether I need to upgrade.
its should be fine thats what im using for my r33 calipers front and rear.
The BMC in my A31 is a BM50, but it is the 2 port version as it has ABS.
The biggest 3 port BMC in Nissan Australia's database is the BM50 (1"), as found on R32 GT-R N1's.
These are the part numbers:
(5) #46010-05U01 | *RB26DETT.GT-R.17 | Tokico 1" N1 Specification
(6) #46010-05U21 | *RB26DETT.GT-R.17 | Nabco 1" N1 Specification
They retail for around $530 brand new, and you'd be lucky to find a second hand one.
Cash
Ah yes, I found this info the other day but I couldn't remember where. Do you have a link to the page (was something like a writeup about some guy doing the 33GTR brembo caliper conversion on his S13.
As for the $530 brake master, I think it would be cheaper to just fit the corresponding brake master (in this case, the R33 GTST) and then have the brake lines modified to fit. Hell, for the savings made on the BMC, you could probably have completely brand new lines made to fit.
Edited by daisu
Yes it was. A friend was/is doing a ground up S13 build and has done all research on master cylinders.
Link to the the blog:
Sillbeer
Cash
the reason i went with the bm44 with the 3ports was because r33's use a 2 port BM 44 not bm50 ......so i felt it was fine. I know this cos the car i took the r33 brakes off had the bm44 on it but it was abs and 2 port so i didnt take that and when and found a non abs one instead ...which too awhile to find.
The pedal shouldn't feel softer when going from the R32 GTST to R33 GTST brakes.
It should feel better.
The R32 GTST and R33 GTST callipers are identical in piston dia; so the same amount of fluid is displaced.
The difference is in their mounting position. The R33's are spaced away from the hub more so to allow the use of a larger dia rotor.
The larger dia rotor with the same calliper offers increased leverage when stopping the car; so less brake pedal effort/travel is required to slow the car.
If the pedal feels softer its possible the callipers require an overhaul or you disturbed the master cylinder during bleeding.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
