Sorry guys should of said that its out of a ECR33 1995 MOD ITS GOT A SERIES 2 MOTOR IN IT
the condition is a1 its got to adjusting screws on the top and got 5 wires (red,orange,black,yellow,white)
sorry about the pic quailty
Please note that you only need one of these if you have an atmospheric(sp) BOV, all it does is raise the RPM when you depress the clutch, very handy if you dont want your car stalling at the traffic lights, you can also raise or drop the ideling, which is handy if you are in to drag racing or getting hard launches, interesting to play around with, i have never heard of needing to have two of them, unless you have an RB26 then you may need two, i have one in my R32 Gts-t and it looks just like this one. I did have alot of trouble finding out what it is, and this is what i learnt but feel free to correct me if some one knows better, $50 also seems like a bargin so some one pick it up
  • 3 weeks later...
I'll give you $50 if you can mark which wires go where as im presuming you dont have any install instructions let alone english ones also is all the plug and wiring there? anyway I would need it posted to canberra
let me know
Thanks
Antony
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
