All parts available at the moment, i have made a short list of parts, but if theres something that you want and i havn't listed it pm me.
located in Clayton, S.E Suburbs
Take the lot for $600 (- brakes, bov)
Parts available
Front calipers, rotors, pads $400
Brake master cylinder $80
Diff was 300 Now: $250
Tailshaft was 150 Now $100
CLutch Master Cylinder was 100 Now $70
Full doors was 500 Now $150
Cabin Light was $30 Now 10
Passenger Seat (cleanable stain) was $120 Now 50
Drivers Seat was $150 Now 80
Roof Lining $30
Carpet $40
Jesus Handles $20 pair
Vents $10 each
Handbrake $120
Passenger Window Control $80
Handbrake Skin $10
Under steering wheel plastic $20
Indicator Stalk $50
Wiper Stalk $50
Sports Wheel & Boss kit $100
Steering Column Surround $30
Rear view mirror $20
Fusebox $30
Seatbelts $50 pair
Rear Seatbelts $30 pair
A Pillar plastics $50 pair
B/C Pillar plastics $60 pair
Front wipers and motors $60
Rear wiper and motor $60
Washer bottle $20
Overflow bottle $100
Air Conditioner (full system) $100
Rear window $100
Drivers window $70
Passengers window $70
Drivers ¼ window $40
Passenger ¼ window $40
Added: 1 x stage2 BOV with adapter for 33 and possibly 32/34: Asking: $150ONO
Photo's: taken off due to loading time, PM for pics
Edited by Taso84
https://www.sau.com.au/forums/topic/184498-all-sold-sorry-guys/
  • Replies 85
Do you have the B pillar interior plastics?? The bit between the front doors and the rear 1/4 glass? Some moron installed tweeters there in my car and I want to replace em....
Just the top parts between the glass... never looked at em closely but I imagine its two seperate pieces!
yes selling the whole thing 2gether, do u want drivers or passenger seat?
Price has been posted
cheers
Both sides please! Can you PM details
Cheers,
Anna
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
