Item: Stainless Steel Dump/Front Pipe with screamer pipe to suit RB.
Condition: Perfect condition, used for just about 5 months on my car
Other Info: Note the length of the screamer pipe, long enough to stay away from anything on the engine bay.
Also note the pipe going right into the dump outlet to minimize turbulence there.
All in all good design,
Reason for Sale: I have a new external wastegated set up. :blink:
Location: Adelaide, will deliver anywhere in OZ for an extra $10
Price: SOLD
Pictures:
post-18416-1189765719_thumb.jpg post-18416-1189765735_thumb.jpg post-18416-1189765751_thumb.jpg post-18416-1189765765_thumb.jpg
Cheers
Ric
Edited by Richo
https://www.sau.com.au/forums/topic/185044-stainless-steel-dumpfront-pipe/
i had always thought a front pipe was the pipe between a dump pipe (wat u have here, only instead of being a spilit dump, ur wastgate side has been chopped off therefore making it a screamer pipe) and the cat-converter?
hmm, not sure now, confused.
What you say makes sense, perhaps this is only the Split Dump with Screamer to bolt onto your Front pipe, would that be correct??
anyway, buy it ,chuck it on, and hang on to your knickers :worship:
PM replied too.
ahah yea maybe screamer just welded onto the flange as well..no worries man was after a front pipe. GL with sale (urs looks hot btw my screamer is only down to the connecting flange :worship:
hey mate
so if i remove my existing dump this will replace it hassle free? pretty keen dude
wouldnt happen to have a pic of it fitted?
cheers
Hey mate
yes it replaces the existing dump, its pretty straight forward really, a bit tight space wise to install but youll get it there, if not you can get someone else to do it for you.
No pics of it installed im afraid.
Cheers
Ric
hey mate
cheers
mate i'll be putting mine on in a coupla days so will have some pics to show wat it looks like!
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
