Hey, there is a bit of a problem. Just put highmount turbo on an RB25DET and it has developed a missfire.
Pretty much everything has been checked short of spending a few hours to pull the injectors out, but cyl 2 isn't firing.
There is injector pulse, a good sized spark, and a good 130-140 psi in the cylinder. Can't seem to figure out whether it could be a tuning issue or what??
The car went from dead stock, in the process fitted nismo injectors, nismo fpr, z32, power fc, high mount turbo set up (the whole lot using brand new parts), and all of the said has been deca checked to try and sort this issue out. All the pipes on the manifold have turned the usual yellowy tinge except cylinder two, the plug pulls out wet, yet it's definatly firing a good spark so maybe its a timing issue????
ANY info at all would be like gold...
Cheers,
Jayson.
https://www.sau.com.au/forums/topic/185400-rb25det-dramas/
