I need a pair of 17's to be used with 275 Drag radials.. dont care what they look like as long as they fit r33 GTSt and are not cracked or warped..
Also i need in good condition Mickey thompsons Street ET radials 275/40/17 or something similar..
cheers
https://www.sau.com.au/forums/topic/185518-rims-17s-pair-and-drag-radials/
Would you like a pair of Super Advan SA3R's?
I have a pair in all black, 17x9 +38, perfect fit for R33. Can even drop them off to you if you want, just need to organise it so my car has something else to roll on while I do a bit of rim juggling.
hey mate thanks for the reply..
how much do you want for them?
