hey Clint32 did you notice much difference goin from 4:3:1 to 4:1:1?, I read on www.calaisturbo.com that its's worth dropping in 4:3:1 that the r32 gts-t has combined with the engine/gearbox conversion to get the most out of the conversion, my only problem with the conversion is that the speedo is about 20km/h out!
https://www.sau.com.au/forums/topic/18561-diff-ratios-r32/#findComment-412514
  • 8 months later...
4.3 = 3700-3800 in 5th at 110km or around 3500 at 100km/h in 5th. mite sound like a bit. put your foot down and your on boost in around.0000000003 seconds :P lol.. so its alright for taking over slower moving cars.. or when you want to race your mate in 5th gear.. lol. but yea.. your looking at higher revs for any given speed in any given gear.. remember that. but i like my 4.3's
https://www.sau.com.au/forums/topic/18561-diff-ratios-r32/#findComment-714664
  • 3 months later...
I just had my diff pulled down and it had 4.11 ratio from what I was told.(92 R32 GTS-T)
While I'm at it does anyone know where I can get a new crown wheel and pinion gear set (4.11) for an R32 GTS-T?
I ask as the old crown wheel is marked and I decided to not change it (to save $$$)but it still wines a fair bit so if I can get a new gear set it would be nice.
https://www.sau.com.au/forums/topic/18561-diff-ratios-r32/#findComment-898671
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
