Hahaha yeah the guy who I got it of was a champ :(
On another note, I have found a buyer for the car if it is stripped of the majority of pars, hence the car will be sold minus the majority of its setup within the next two weeks unless somebody forwards an offer on the car as a whole. Would prefer to keep it in one piece so get in quick!!!
https://www.sau.com.au/forums/topic/185840-sold/#findComment-3378268
Internals are stock including cams
As for the PSI rating of the turbo, no idea what psi its rated at, but the power rating is 480 hp approx. A guy on here ran 23 psi through one of these and with it being an hks turbo I would imagine it can take alot more
https://www.sau.com.au/forums/topic/185840-sold/#findComment-3392760
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
