that fascia is off the car i asked him about it as i wouldn't mind a new 1 but i dont think he answered me
when i see him next i can ask about it as i wouldn't be needing that part
yeah Joel Rear is fine
you mean a single din pocket i cant remeber if i gave mine away ill have a look if i didi ill get it back off the guy if he still has it
if i cant get it there like $10 from toyota im sure nissan are the same
Edited by Madaz
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
