Hey guys,
Im chasing up some parts for a project i want to do.
Im in need of an R34 front bar and bonnet (stock or aftermarket), and a pair of headlights.
Would be alot easier if front bar and bonnet were painted white but if not well we'll go from there.
So yeah just let me know what youve got.
Cheers :)
https://www.sau.com.au/forums/topic/186143-wtb-r34-panels/
  • 5 months later...
  • 3 weeks later...
