Not sure which series this RB26 head come out off.
Really sad to letting it go but hopefully i won't regret it as i was planning on using it on the next car.
It is in good condition all that is damage are one lifter.
It DOES NOT have Rocker Cover gasket With CAMS but no cam gears.
$600 Pick up from Sydney,Liverpool or ship at your own expense.
Edited by Deceeve
https://www.sau.com.au/forums/topic/186414-rb26-head-for-sale/
ok, so it does have a rocker cover, just not gasket?
Thats cool, and the only other thing missing is the cams? Are the lifters valves, springs etc still there?
There is no rocker nor gasket
Yes the valve springs and lifters are all there. Just one damage lifter
these heads with valve gear and rocker covers normally will fetch up to $1000 plus freight no need to drop the price
also try advertising on
nissansilvia forums
calaisturbo.com
I thought it's a decent price and it is still in fairly good condition apart from the one damage lifter.
Still for Sale!
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
