Hi guys im selling my roll cab as i no longer need it
ITEM: Chicago numatic cp743h air rench (impact gun)
OPERATION: 4sp fwd and reverse compressed air
PATS INC: gun 1/2" 5/8" 3/4" 7/8" 15/16" 14mm 16mm 17mm 19mm 22mm sockets all impact
PRICE: $130 use was one year
COLOUR: black with gold edgeing
BRAND: repco
SIZE:
DRAW X 5 @ width: 22.5cm x height:6cm x depth: 40cm
DRAW X 2 @ hight 15cm x width 22.5 X depth: 40cm
Total 120cm h x width 58cm x depth 46cm
AGE: 1 yo
PRICE: $500
PHONE: 0411 895 116
EMAIL: [email protected]
this roll cab is a limited edition recpco 7 draw roll cab, all draw have strong magnets on the end to stop them from operning when on a slight angle and full of tools
(this has saved me damageing cars). there are auto sitckers (k&n, blits, hks ect) on the side. it cost me $750 brand new. it has being used in a work shop for 1 year, and i now longer need it as im no longer a mechanic and it is tool big for what i require.
inspections welcome. i will be posting pics at a latter date when i recive them from my dad who has the roll cab in melbourne as i live in wagga wagga.
so please call or email me to arange a time to go and have a look at it.
chears brentt
https://www.sau.com.au/forums/topic/186486-roll-cab-and-impact-gun/
