SOLD.
Hi,
I'm selling my track wheels.
Buddy Club P1 Racing, in dark gunmetallic grey (this colour no longer available in this model).
These are proper, lightweight, forged racing rims.
No, these are not the newer "QF" or "SF" or "II" model.
Come with original blue valve stems and dustcaps.
From memory one of the rears has very light kerb rash about 20-30mm long. Otherwise immaculate.
They have been sitting in my garage for the past 6 months.
They have only ever been used on the track.
They weigh bugger all.
New, the wheels alone retail for about $500 per wheel.
17" x 8", offset 32, 5 stud, 114.3mm PCD (front)
17" x 9", offset 37, 5 stud, 114.3mm PCD (rear)
With semi-slick tyres:
Bridgesone RE55s, 255/35 front + rear, medium compound. Worn and definitely not road-legal, but enough tread for 1-2 more trackdays. These tyres have minimal tread-depth when new anyway. No flat spots or damage.
I can confirm these fit fine on an an R34 GT-t 2-door, and somewhat amusingly also on Ford Falcon XR6 Turbo. They should be fine on any GTS/GTSt/GT/GTt.
$1800, ONO.
Pickup preferred. Southside suburb of Brisbane.
No swaps, unless you have the exact same wheels in 16", 4-stud pattern.
Make me an offer. :whistling:
Grant:
http://www.skylinesaustralia.com/forums/t8...=offsets+r32%2A
For R32 GTSt, the answer seems to be "probably", but you might have to do something minor like get the guards rolled.
From this thread: http://www.skylinesaustralia.com/forums/t8...=offsets+r32%2A
Just copy and fill in the table;
Skyline model = R32 GTSt
Wheel diameter = 17"
Wheel width = 8"
Wheel offset = 32
Tyre size = 235/45
Modifications to fit = Roll lip
Wheel width = 9"
Wheel offset = 37
Tyre size = 255/40
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
    • lights are on just the one click.
    • Absolutely matters because, while a temperature change will eventually reach a sensor at the end of a static line, the response time is far far far too slow to be useful. Might as well not have a temp gauge at all.
    • When I was eyeing off the 370GT (after deciding I didn't want to spend 30-40k+ to relive my early 20s in an R33) I thought it'd be a good project to add a turbo to it. Now that I have a 370GT, and I've had a couple of chances to open it up, I'm pretty stunned by how much power it makes 🫠 Honestly, the way the VVEL opens it up, it almost feels like there's a little turbo tucked away in there somewhere. It's like Nissan looked at VTEC and said "hold my beer" 😁 Has anyone thrown a turbo into their 370Z or 370GT? Is there a conservative boost level you can run without having to upgrade the fuel system, or are bigger injectors and a bigger pump a given?
