Hey,
Well, here's the problem I'm having with my R33 GTST at the moment, I had coolant spilling out of the overfill tank for a couple of days, however the coolant levels and running temp of the car was fine, it wasn't overheating at all just normal running temp.
I however, took the car to a radiator specialist and spoke to someone there about it, he said that the radiator cap needed replacing (even though I replaced it about 4-5mts ago). He also said that it wasn't sealing properly.
He also went on to say, best bet is to get a 16 pound radiator cap or replace it with a genuine Nissan one, which I will do tomorrow.
Nissan sell them for $21 and a 16 pound one from Autobarn is $50.
Anyhow, while the car was parked at work today there was a puddle of coolant on the passenger side of the car, it was really weird being dark I couldn't see where it was leaking from so I toped it up drove it home and it was alright.
Though, I'll have to have a look at it tomorrow when there's some more light, just wanted people advice/help on what things I should look out for, thanks.
- Aron
https://www.sau.com.au/forums/topic/186508-coolant-leak/
Stock cap. High pressure radiator caps should NOT be used on a factory plastic radiator.
In the event there is too much pressure, rather than the cap blow, it will shatter your radiator to pieces and cause a mighty mess :whistling:
Factory all the way
https://www.sau.com.au/forums/topic/186508-coolant-leak/#findComment-3371086
Factory all the way
Yeah, I was never planning to buy the 16 pound one, just the genuine Nissan one.
Do you think that could be the only problem though? What else should I check for tomorrow?
Thanks R31Nismoid,
https://www.sau.com.au/forums/topic/186508-coolant-leak/#findComment-3371089
If the overflow isnt leaking, and the radiator cap is new.
You have a crack in the radiator somewhere i would imagine, or turbo line possibly as you said passenger side.
Maybe a leaky plug somewhere around a water gallery.
Things like that can be hard to find as the water runs along parts, so it could be coming from the other side of the car, best to trace the leak if the cap doesnt fix it.
The radiator cap lip is plastic isnt it? So it cant be that.
https://www.sau.com.au/forums/topic/186508-coolant-leak/#findComment-3371106
Here's the update..
I went and picked up a genuine Nissan cap this morning and put it on, started the car and noticed that there is coolant dripping from underneath the car, around the area of the oil sump and fan belts, can't seem to pin point where it is coming from though, any ideas?
https://www.sau.com.au/forums/topic/186508-coolant-leak/#findComment-3371352
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
