  • 2 months later...
everyones got there own taste guys! i happen to like them and they do look good in the flesh, i only want to sell them cause i want 19's (im not after opinions on them, just interested buyers please)
INASNT
i cant lower my car cause i have the 400r front bar and it scraps heaps as it is at standard height, so i need to fill the guards up more by putting 19's under it.
To the Gentlemen that posted their dis-like to these wheels,,,you have been deleted,,,,PLEASE keep your comments to yourself. He likes them and I'll bet lots of others will as well,,, so please keep your comments to yourself. Reading the rules would help.
Good luck selling them Mate and a Free Bump to boot.
Neil.
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
