Hi All,
Can I get an idea of who would be interested in a paintball event
Likely cost $60 for 300 balls +15 per extra 100 balls.
Likely date 27 October
Feel free to invite friend's family and people you really want to shoot.
We will need 10 paid up entrants before it goes ahead.
This is for interest only, I am not asking for payment yet.
https://www.sau.com.au/forums/topic/186910-interest-in-paintball/
I was thinking about PMing you about it today,
I recommend the one out at the airport - I have been there, and people that have been to the ones all over canberra seem to think its the best, "Cause of the maps.
I am in for it and i am sure i can get a few people along if its at the airport one.
The last big paint ball we organised we all payed the organiser the payment in full before the day.
This work extremely well and we had Not ONE person miss the day, out of 30+ people.
+ it ment that it didn't seem that bad to buy extra paintballs.
Cheers
Keith
Just a bit of stuffing around and drama
http://www.skylinesaustralia.com/forums/t1...mp;hl=paintball
Holy cr@p!! Did it go ahead? Drama is an understatement... I don't know how I missed all that, I must have been keeping quiet (don't even think about it Mick :D)
No it did not go ahead, but after constant reminders/damands we did all get our money back.
The organiser this time has a little more experience and no weaselly partner :P
I doubt many from CC could afford it since they are all still in school :ninja:
Maybe street rides though, not sure about NS, but maybe.
But im working that weekend, sorry.
Edited by datto260Z
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
