Hi guys,
Need to get rid of some items due to finances as i need to get some new tyres.
All items priced for a quick sale:
2) Sets of MTX Thunderdome Coaxial 6.5" Speakers: BOUGHT: $159ea SELL: $85ea
EDIT: SPEAKERS ARE BRAND NEW STILL IN BOX UNUSED
Frequency Response: 48hz-20khz
Impedance: 4 Ohms
Impedance Rating: 4
Included In Box: Manual
Mid Range Size: No
Mid Range Style: Info Not Available
Mounting Depth: 2 1/16"
Power Handling: 120 Watts
Product Dimensions: 22.0(W) x 10.5(H) x 42.0(D) cm
Product Weight: 2.9 kg
Recommended Power Range: 120 Watts
Sensitivity: 92Db
Speaker Size: 6 1/2"
Speaker Type: 2-Way
Pictures for illustration purposes.
Apexi Power Intake Filter (Panel Style) PRICE: $30
Apexi Part: 503-N101
Greddy Boost Guage - Electronic Warning Series w/- Recall BOUGHT: $390 PRICE: $160
Comes with wiring harness, boost sensor and computer.
Still in car. Glows green. Picture for illistration purposes. Colour White
Gizzmo Intelligent Boost Controller (Used) SELL: $190
Comes with boost solenoid and wiring harness. Still in Car. Picture for illistration purposes.
Four Boost Memories
Adjustable up to 2bar (29lb)
Fast RISC Processor Technology
Real Time Digital Boost Gauge
Extruded Alloy case
Simple 2-wire installation
Suits internal or External Wastegates Comes complete with all Hoses and Fitting
The Gizzmo IBC (Intelligent Boost Controller) represents the ultimate in Accurate, Simple to operate, and Easy to install Computerised Boost Controller.
Because all the thinking is done inside the IBC, you will not require an Engineering Degree to operate or fit it.
With the Gizzmo IBC’S precision 29Lb MAP sensor, High Speed RISC processor and Powerful MOSFET solenoid driver, and the fastest, most powerful solenoid you can be assured that your Gizzmo IBC has the Quality, Resolution and Accuracy that you need for your Turbocharged vehicle.
Additional Info --> Click Here
Prices are ONO...
Pickup from Parramatta Area prefered
If interested please pm, sms or call on 0448 944 096
Cheers all
-Brenton
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
