i think you'll find that they wont publish the paint codes for their cars, same as yamaha doesnt publish paint codes for the R1's .. so it can only be purchased through them for those specific products.
good luck with the search though
https://www.sau.com.au/forums/topic/187578-ferrari-f430-gt/#findComment-3385264
i think you would have to ring a dealer and plead with them to give it to you. and even then you would probably have to buy the paint off them too.
otherwise go to a paint shop and get some marinello (sp) red. i know holden uses that colour.
https://www.sau.com.au/forums/topic/187578-ferrari-f430-gt/#findComment-3385313
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
