Obviously you don't know NSW rules.
There is no point in buying such a performance car when you are such a young driver. Learn how to drive first. Petrol is expensive so is rego, insurance and greenslips. I know a quite a few NA's that will beat turbo cars on the track.
I guess in the end if you're going to do something stupid in the car, no matter what car it is you can still end up killing yourself either way.
i live in qld corinne, so you'd be correct :P
where's the reasoning behind not buying one? if you're basing it on financial position (i.e. petrol,rego, insurance, slips); then it's obviously variable from individual to individual. also correct on 'no matter what car', if anything i would think one would look after their pride and joy alot more than a clapped out tissue box with oreo wheels.
As a suggestion, why not do a few track days to become a half decent driver?
nicely put... f1 drivers don't drive around in corollas for 2-3 years and decide to go pro. they build up from go-karts, etc.
RED P platers cant do any Performance mods, so anything that makes the car faster, i.e exhaust. pod etc...
is this restriction only to power mods? there are other ways to go fast; driver skill, suspension?, learning the track, track rims w/ semi slicks, wheel alignments, etc.
hmmm just wondering...why dont u import one?...
to buy a good 2nd hand gts in aus, will cost u about 13-15k.
but if u import 1 from japan, u could get it for 11-13k easily.
i imported a 96 series 2 gts for about 11k, including compliance and all.
Actually, the wording on the RTA web site is that P platers cannot drive a car with engine performance modifications.
Ironically, the letter of said restriction means if you put a higher RON fuel in....you just technically violated the terms of your license. Same with putting more restrictive bolt-ons. Reducing power is still "modifying" power.
However, there's no rule that says a P plater can't drive a car with the interior gutted (in a fashion that is legal for a full license holder), R Comps, and a close ratio gearbox / final drive, That kind of legal modification still gives the car a higher effective power-to-weight, and more acceleration via gearing and initial traction. They can also run aftermarket suspension as well, and increasing their cornering speed / reducing the approachability of the handling limits....which for an unskilled driver is also a recipe for an accident.
do this with an rb25de r32... lighter base to start with, with the same motor, and put bigger brakes, helps catch up too the turbo boys who fly down the straights then pull up short :laughing-smiley-014:
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
