  • Replies 88
Pfft thats the silliest thing ive heard, where the **** does the air fuel come from. Its only air :[ FFs some pplz that make the rules got no idea. Pressureized air intake does not contain fuel or oil and how can fuel get back that far theu the manifold to the BOV when pressurized. ROFL. Normaly aspirated cars do that if they have a BIG cam with lotsa overlap but not turbo. They call it "reversion" u can even see it on my car without the air filters off but ide rather keep them on. ADRs r BS for cases like that. Most times the aftermarket items r much better quality and r safter than most stock chepo items. just think of it like i do, the GOV has their hand out for any $$$$ they can get to pay off forign debt. One reson i dont own a Skyline Sif put up with all that BS from them so i can pay them more money.
erm hate to tell you brad but it does contain Oil.....
Thats what Catch Cans are designed for.
To prevent oil sludging up your IC & allowing oil vapours to enter your combustion chamber etc etc.
I'm not to sure about fuel vapours but then again it does seem logical as what happens to cars that are driven on short trips only? Their oil starts to get contaminated with fuel. Only by a small amount but its still there I guess.
Raises a point I didnt think about, as road traffic act requires all crankcase fumes to go through the plenum, if a BOV vents to atmo, spose they arent getting to the plenum even if you use a catch can.:) Got us on that one, but I bet not too many cops would think of that one.
Originally posted by GTR King
Fuel in Oil is from Blo by past the piston rings, Joel can u tell me where oil can get into the intake manifold. Got me stuffed what u r on about.
Brad...
A oil catch can is to prevent oil ingestion in to the turbo and intake.
Similiar to when a motor is breathing like fark and you see oil splattered all over your air filter (in a carby car) 626 Mazda for example.....
You didn't know that?!?!?!?!?
Do a little bit of a search with regards to why catch cans are fitted and how detrimental not having one on a boosted engine can be when driving it constantly hard.
It can also occur when the turbo's compressor oil seal is stuffed.
Joel, I think the problem is that GTR King is maybe used to old school (pre emission) cars - the crankcase gasses are vented to atmosphere via the oil filler cap, just a pipe from the crankcase to the rocker cover, and mesh in the filler cap with a hole up the middle - bit like fitting a atmo rocker cover vent on a skyline.
GTR King, to carry on from what Joel is saying, the crankcase gasses on a skyline goes straight into the plenum when not on boost, when on boost, as the plenum is pressurised, the gasses get plumbed back into the airpipe that connects the afm to the turbo - this then coats the turbo and cooler in a slick oily coating - especially if you have a bit of blow by, or are running increased boost without a catch can. This has potential for causing detonataion too, as you may be able to imagine.
When I took my stock cooler off, the inlet side was black, the other side was grey/normal - this was with stock boost - pretty shit really:(
yeah, what Steve and Joel said :D
I often give my blow-off valve a bit o a wipe and always get plenty of oil off it (and other lubricants by the smell of it). I don't understand why, I just know it's there ;)
Yeah even my car has vented crank case and a catch can:] Tho old school cars did have PCV valves in the Rocker Cover back tho the Inlet Manifold. Didnt think Intakes on Skylines would have recirculation as i chums up the throttle bodys and Map sensors etc. Tho i forgot about oil seals on turbo main shafts, tho if they r leaking u deffinatly got a prob :[ Man i got stop saying that word Turbo, just makes me wanna buy one.
Originally posted by TIMMMAYYY
PCV valves? vented crank cases? Catch Cans? Oil coming out of BOV"s?  Im confused :D
No worries, will do my best to explain:
PCV valves - Positive crankcase ventilation valve. Positive crankcase ventilation, is the removal of gasses from the crank case (which are caused by gasses from the combustion process being forced passed the cyliners, called blow by). These gasses generally are vented in to the rocker cover (or cam cover). From here they go directly into the plenum when not under boost. To stop the gasses from going in the opposite direction a one way valve is used. PCV Valve.
Catch cans - when a turbo car is under boost, the gasses from the crankcase (the blow by) cannot go into the plenum as it is pressurised, so they are plumbed into the intake before the turbo. Blow by is made up of combustion gasses, contaminated with oil and a small amount of fuel. This goes throught the turbo, intercooler, BOV (oil coming out of BOV)when venting and eventually into the cyliners to be burnt - pollution control. A catch can fits between the cam cover and the intake pipe to the turbo, and removes by filtering, the oil and particles suspended in the blow by.
Hope that makes sense
yeah RB30 would be the go but i wanna keep it sorta origional looking. Turbo make huge underbonnet heat and i dont wanna have to vent my bonnet or wreck my paint. My old man is building a 600hp+ rb30 for his co drivers new EH drag car hes building. See how that goes first then ill decide. Supercharged Methanol sucking rb30. Should be running Mechanical fuel injection. None of this expensive computerised stuff, who needs it :[ Cant wait to see how it goes. Tho it aint very aerodynamic. It will be a full chasis car tho.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
