I have heard that if you put the apexi pfc on the rb25det its very hard to get it to tune over 450hp. Is this an actual problem or have I heard the wrong information. I am in the US and will be in need of complete engine management. This sounded like a good choice unless it will only tune to 450hp. Thanks
https://www.sau.com.au/forums/topic/18822-apexi-power-fc-limits/
I think you have heard the information form some oenwho doesnt know the power fc because there are a number of car on this board tha make in excess of 500 hp that use the power fc in fact the power fc is the ecu of choice cause all you have to do is plug it in no messy installs. btw that is assuming you have a suitable turbo injectors, fuel and afm.
cheers
I think the version you are refering to is the Djetro....
This is just means that the primary sensor of the computer is undertaken using the MAP sensor rather than AFM. Hence no resolution limits using AFMs! (allthough AFM are more accurate)
Heres a power restriction guide for you if your going to run a AFM setup:
1 X RB20/25 AFM = 370 bhp = 220 rwkw
1 X Z32 AFM = 420 bhp = 260 rwkw
2 X RB26 AFM's = 475 bhp = 300 rwkw
2 X Z32 AFM's = 700 bhp = 470 rwkw
1 X Q45 AFM = 480 bhp = 300 rwkw
2 X Q45 AFM's = 850 bhp = 550 rwkw
I havent seen anyone using a Djetro version of the FC so i cant say how it performs. And as for the diffrences regarding the computers i wouldnt have a clue! :P
Cheers,
Trev.
Hi guys, there is a lot of AFM paranoia floating around. People forget that the AFM is not the only method by which an ECU determines how much fuel to add. It also relies on throttle position and engine RPM for example. The standard ECU is programmed to add fuel and retard the ignition when it sees 5V, you don't have to program a Power FC that way.
When you build a fuel map in a Power FC you can table the air flow up to 5V via the AFM and then rely on RPM to table the fuel required once past 5V. RB engines are very linear (with RPM) in their fuel requirements at that level, so this is not a difficult or dangerous proposition.
Using an AFM with resolution available at higher airflows would make this process even more accurate, but there are plenty of engines around running perfectly fine without it.
As I do with everyone, I suggest you fit the PFC, have it fine tuned properly and then read off the AFM voltage from the Commander. We have seen 250 rwkw on the standard AFM at max voltage.
If and when you reach that level, then a Z32 (80 mm) or Q45(90mm) AFM is an easy upgrade for a few hundy.
Hope that helps
Hey People
Just after some help. I receantly got my power fc with h/c, boost control and exhaust cam gear installed on my 1993 GtsT.
It already had 3" exhaust with dual dump pipes, Apex GT intercooler and pod air filter. Since the new gear has been installed I have only recieved about an extra 22rwhp. Does this sound right?
I ran a thread before I bought the PFC, boost cont and cam and was told I should have been able to get close to 200rwkw. I'm only at about 187rwkw. Any advice would be great.
Thanks
Chris
Hi GTS 33, unless the dyno room is airconditioned, ambient temperature could easily account for the 8% difference. Remember a decrease of 8 degrees Celsius = 5%.
We had a super cold day last weekend (6.5 degrees) and I whipped the GTST on the dyno and it pulled 230 rwkw. Previous best was 210 rwkw at 25 degrees. No modifications since.
Comparing different cars on different days is waste of time.
It's the 22 rwhp increase over the day that is more interesting. Experience would say 5 to 10 rwhp for the exhaust cam gear and 15 to 20 rwhp for the PFC. Then you would have to add the additional hp from the boost increase, if you had any. So 22 rwhp looks a little on the light side.
I would look at the air fuel ratios, the ignition timing and the boost and make sure they are all optimised. Also check the exhaust timing, it should be around 4 degrees retarded for max hp.
Hope that helps
Hey SydneyKid
Thanks for that info. Not really clued up on the pfc as yet, still gotta have a play. Do you have any advice of what the air/fuel ratios, ignition timing and boost should be set at for best results without damaging anything?
Pretty sure my boost is set at 13.1, spoke to 25GTT he says that might be a little hi.
Thanks for your help
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
