Had a nice surprise waiting for me at work this morning.
Last Years 300C Safety car from the V8s was waiting for me at my office :laugh:. Straight through 3" exhaust sounds REALLY TOUGH. Dont know what they have done but wheel spin when every you try and drive it either forward and back ( and not at 100% throttle :) )
i can say its the only time i have had TOLL paperwork stating
Departure : Mount Panorama
it looks as though it has had a very hard 6300Km's. plenty of paint damage, skid panels on the ground. It feels like it has done 600,000Kms.
Driving a left hand drive is really weird. Got some pics just need to find the cord to get them off the phone
fitted a GFB Stealth FX bov today, got it for 200$. got it on full 'silent' plumb back mode with spring strength around 80%, sounds funny when you let your foot off the gas..... :laughing-smiley-014:
out with the video camera Brendan you know we want to hear it :thumbsup:
hahahaha will do. did a recording on my mobile phone as I was testing. cant hear the 'flutter' sound under off-acceleration with only mild boost. with full bost all you hear are big "whooshes" but its the flutter that sounds funny. like a wrx with a dogbox and megaphone-atmo bov. not hugely audible but its there.
just need to add a small correction to the safc up at around 6000rpm, got a little ping.
funny shite. gone from wanting to keep it quiet to hiflow turbo, pod, whooshy bov, rumbling Kakimoto muffler, etc. makes a fair old racket now. sounds cool tho
yeah i was thinking of new muffler 5" Kakimoto but want 5 stud conversion and new rims first if i do change i want subtle note all the time with a roar when above 4,000 atm its loud all the time
hey i think i forgot to give you a trader rating for that CPU sitting on my shelf ;)
Hey brendan!
How ya doing? How's the knee pulling up post surgery? Hope all is well and your enjoying (as best you can) your time off work. Sounds like you been having some fun with the car, will have to swing by and have a better look one weekend :down:
Cheers
Lee
yeah 4 sure !
:down:
pretty sore the past 2 days just after leaning over the bonnet installing the bov for half hour on saturday.
damn, all good tho coming along. start physio, etc this week.
:) w00t MV Autos today getting the shift kit installed and auto serviced :)
nearing the end of the mods
no more boooooooost, high rpm goodness, whoooooosh, boooost, higher rpm stress, ign cut, nothing.....nothing.......nothing......(ping), flare + change.
just BANG change
lol
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
