was pretty happy with the economy of my car today 608Km's out of a tank. Would have been better if the ultimate was $160+ in the middle of nowhere
down side is the car is pinging due to the crappy unleaded that went into it. I think i need to flush it out and run some good stuff in there now i'm back in civilization :cool:
bit sad that my 33 is my daily and i have done 26000Km's over the past 3 years and have done 2000 in the last 4 days
i know that feeling mine is daily driver aswell thats alot of kms how did it go in the heat
yeah that nearly 1/5th of my annual Km's and i might be heading up to QLD in the next week or so and that'll add a lot more
pretty well, i flushed the oil and radiator ect before i left so i wasn't to worried.
It might need a wheel alignment as it pulls to the left when the wheel is straight :cool: have to wait to i get a new job
i noticed it on the way over, it could have been doing it a while i just don't drive enough to notice (long straight roads anyway) not that fun when i went to grab a drink and the car starts to drift off the road when it should be driving straight.
not the most comfortable seats for long drives
Yeah right, :cheers: unless the height of the mount is actually different to standard nissan.... the engine would be in the same place no matter what.
Dont make sense though, would mean different gearbox mount etc....
Inless its actually shaped different to clear lines or something. I dont own a 33, so Im trying to use logic here LOL.
Edited by R31 drift pig
r the gtr seats any better to sit in does anyone know." 4 long drives that is"
Yeah there nice...I dont mind them and sat in one for 6hrs from Sydney to Shepparton ;) But I was driving I guess you would get fidgety if a passenger ;)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
