How much is the z32?
If you buy it get a fire extinguisher just to be on the safe side lol. I know the old z31 got a recal from factory due to catching fire and iv been told the z32 isnt any better due to engine size and fuel lines.
I love my Zeds but the vg engine has always kept me away
I heard that the VG engine is sweet as, its just the rest of the car isnt built too well around it (mainly cramped and overheating issues) ?
Probably could get it for around $5k maybe under.
had mt 1st driving lesson today, i was freakin out so bad
but it was awesome, i got good on everything :down:
I doubt you got good at everything ... but its good to see you learning. Just keep a straight head when driving.
you doing the log book system I hope. Taking lessons from a qualified instructor?
Hi people of sau sa, my name is Alan, some of you have probably seen me browsing on these forums on a daily basis, ive been on here for couple months now. I just thought i should finally introduce myself :down: . I have been quite interested in purchasing a skyline for quite some time now. Leaning towards an r32 atm.
PS. i do not know much about cars etc (technical stuff), so i hope you can help build my knowledge through answering some of my stupid questions.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
