yeah its all good
in 12 months time Im hoping it'll be heaps rosier
dr tonight asked when i needed him to do the p/work, so yeah Im relieved, 'cause its been so hard, and such a long daily struggle, just to get up out of bed on zero to 2hrs sleep a night, always in pain or spaced off your face due to prescriptions. a decade like that.
so 1 yr out of it to look soley into my rehab will be a good thing
hopefully life changing hey
cheers boys n girls
17" bronze drifteks so a little bit different to Chads
eventually i would like to put 255 all the way round for now will have to settle for 235 untill i can afford new tires my MAXXIS on the fronts were new before i went to melbourne this year the rears are on the wear indicator
lol Dave Ex's from the past are never a good idea to have coffee with :P
i can get NS2 255x17 for 190 i think
i told him there rubbish but he said there are a lot worse tyre like Antyre and Goodride to which im running Antyre on the rears atm
you can see that by going to My Assistant ^^^^
Dan the man is an admin would have to deal with a lot of stupid people asking crazy questions i say stupid becuase a lot of the time if people read through threads properly the answer is right in front of them
>>Top 20 Posters<<
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
