i plan on investing mine in fingerless gloves.
Nah, plan on getting a couple of k back, going towards an Oil Cooler and semi slicks for the 33, then the rest is going towards a 31 simular to my old one.
Gotta love free money!
Edited by Ryanrb25
All my tax refund is going on credit cards :| Maybe I'll have enuff to close one of the two... *sigh*
-D
