Just a Drift Australia update from the weekend for those that dont know the results already :sick:
Toyo Tires Drift Australia Series Eastern Creek Top Eight
1. Leighton Fine (SA, Toyo Tires Nissan 180SX)
2. Luke Fink (VIC, Holford Motors Nissan Silvia)
3. Beau Yates (NSW, Toyota Racing Developments Toyota AE86 Sprinter)
4. Khudar Elhaouli (VIC, JDS Auto Imports Nissan Silvia)
5. Linden Reynolds (SA, WheelWorx Nissan Silvia)
6. Darren Appleton (QLD, Peer Industries Nissan Silvia)
7. Adam May (SA, WheelWorx Nissan Skyline)
8. Adam Trewhella (WA, Miluc Civil Nissan Cefiro)
Toyo Tires Drift Australia Series Standings
1. Leighton Fine (SA, Commercial Truck Sales Nissan 180SX) - 1836
2. Luke Fink (VIC, Holford Motors Nissan Silvia) - 1766
3. Beau Yates (NSW, Toyota Racing Developments Toyota AE86 Sprinter) - 1607
4. Adam May (SA, WheelWorx Nissan Skyline) - 1424
5. Khudar Elhaouli (VIC, JDS Auto Imports Nissan Silvia) - 1401
6. Christian Pickering (SA, Senwill Civil Nissan Silvia) - 1395
7. Robbie Bolger (QLD, VIP Petfoods Holden Monaro) - 1395
8. Tom Monkhouse (SA, Japanese Motorsport Nissan Silvia) - 1382
