i was sick mon tue with the ful or something, got to work yesterday still sick as and got reemed for having 2 days off even tho i had sick cert from dr and told him i was that sick i couldnt even get out of bed to take locky to school and that chad came over with some dinner for me. :D
Then today i get a email BC to me this morning saying he wont be in as his son is sick and his wife is at work night shift and his son cant go to day care, his son goes to his aunty's not day care
seriously WTF is anyone a boss on here what do you think :D
I'm the manager at work Kell. No employer/manager should have double standards when it comes to home-responsibilities. A real manager/employer will understand that personal issues outside the workplace can and will affect you inside the workplace. You getting reemed for time off sick (which was totally satisfactory given your circumstances) and then the boss doing this shows he has unethical double standards.
thats exactly the way i felt this morning when i came to work
i sware im soooooooo :D and :D
Can do, they will prob do it cheaper if its all together. Anyone else need stuff done?
Where? hmmm. RYAN!!! where did you tell me to go to have it done??
You got a quote yet? I want my rims coated in a week or 2 - want to know to organise my own or are we getting discount.
Thanks :D
yeah lol all those suits need to harden the truck up and go take him down
ok anyone able to give me a lift on friday afternoon @ 1pm from Beverly to boostworx ??
Pete? Ryan? save me having to catch the bus :D
I'm all over the place tomorrow Steve......unfortunately I wont know till about midday.
If midday is not too late to organize anything, ring me then and I'll see if I'm nearby.
Thanks :D
Well Jenkies is planning to get his 4 rims done as well, I might give them a quick ring and price up cost per rim, then organise a discount later.
^^^^ thanks :D what does everyone thing about deep bronze an ma baby? sick of cleaning the white every second day.
man those office nuttas cracked me up especially the first one when he stacked it on the desk... he totally flipped! guess stress can really make things go awal!
brings yummi coffe and smoke and time off to kel! big smiles
hrmm, well I just rang around about getting rims coated...
quotes ranged from an outrageous $80 per rim ($320!) to an awesome $30 per rim ($120 set).
Best part is the cheapest quote is only 10 mins from my house, so I'll go visit him this Saturday. :rofl:
Best part is the cheapest quote is only 10 mins from my house, so I'll go visit him this Saturday. :D
Do tell, who is this bloke? :rofl: I wanna get my engine covers and calipers coated.. was told it could take up to a week tho ;\ Guess I'll just have to cut a floor in the gtr and use the flintstone brakes...
-D
AAA Powder Coaters
7 Kitawah St Lonsdale SA, 5160
(08) 8326 2000
They do the blasting and coating in the one workshop, so I guess thats how they keep the cost down. Most coaters seem to outsource the blasting.
AAA Powder Coaters
(08) 8326 2000
Just got quoted, $25 for 4 calipers. Holy smokes thats cheap. $25 for the engine covers too. ;D
-D
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
