ha ha ha ^^ ill be the camera man..
wohoo 800 posts. most of them stupid and meaningless! lol
oh well.
im off to bed, gotta early meeting tomorro morning :O
Edited by craig R33
rad33... When taking it for a bit of a boot take note of the peak afm volts... :(
Hows the highflow feel compared to the stock turbo at 14psi? stock turbo feel like an easier quicker street turbo on the rb20? When I had a larger turbo on my rb20det it felt like it was slower to 100km/h and required lots of rev's off the mark and only once in third was it quicker.
The sad fact is you'll always get used to the power.. 250rwkw+ feels quick but you quickly start to think it could feel quicker. :O
Oh and i just bought some more RAM for my laptop, love the engrish on the back
"Quality is one of utmost important winning formula for Gingle's leading position in memory field. Gingle has developed a quality system and nonetheless we continue to refine our quality management process to ensure customers receive quality solutions cost effectively"
Edited by Damo_R34
Hey Damo! Yeah it is hard living with only 200+kw, so thats why im now pushing 300+awkw! :O
hahahah Ben don't tell people how much that cost you :D and the saga that has gone with it :P
Ha! Yeah ... the cost of absence and headaches ... one pissed off Nene! :) Shall I go on Ben? :(
hahahah Ben don't tell people how much that cost you :) and the saga that has gone with it :D
ha ha i know steve, i literally could have bought another car for the cost of the upgrades, but its the sacrifice we make for more power!
<------ Awwwww, I got another cute bunny! :D
Time to find another offensive avatar :O
I'm surprised the last one lasted as long as it did. :P
ba ha ha hanice bunny fag! jokes, isnt that two bunny's? now u can make a pair of slippers! :(
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
