^ peak power is not everything chase the torque it lasts longer and dosnt require as much thrashing to get around with some decent power plus you can spank people in the wrong gear :)
Oh dont worry, ive got more down low torque than most worked V8's, but i dont run out of steam half way through like they do! lol!
yeah im sure ya do. was intending that for damo ive seen to many go the path of just getting a number to brag with :P
ive seen the grim mobile in action like 4years ago. 1st car i seen shoot flames on the street and the way that turbo sqeelz sounds pretty crazy.
we did have it on film but the stupid cam broke :P
2swift ring any bells mayb not cause the driver didnt put in a good effort at the time :)
Edited by Inline 6
I can vouch for that! Got a sample of "the fury" earlier in the week. :)
Ha ha Inline, yeah GRIM is a lil bit nasty with the flame side of things...its a good way of making people not sit to close to the back of the car when driving!
Yeah you got a mild taste of it on the weekend Roo, keep in mind thats only at 13 psi, wait until we add the other 10psi to it! lol!
Oh, I'm fully aware of the lack of the 10psi Ben :P But I do agree you'd want AWD back when you've dialled in the new boost.
I've wound my boost back to 7psi from 10psi since swapping the turbo, until I can get the SAFC and tune her properly. When I get the SAFC, and do the shift kit, I'll run 13psi and that'll be it performance wise. Like I said earlier, its for that reason that I can't spend stupid money getting stupid power. Been there, done that, many times over. If I wanna go fast now, thats what my bikes are there for :P
... but I have no quarrels riding in the cars of others who have done it :)
Another day.... another defect :D yay.....
That sucks! :(
Me and the GF were out getting takeaway last night and a cop car ahead slowed right down so I caught up with him (me in the LH lane, him in the RH lane). Then the cops took a long hard look at the Stagea ... I turned into the takeaway shop I wanted and I saw them pull across the two lanes and park up the road. They must have given up, by the time we got our order they couldn't wait :D
Yeah, i was down arndale way. There was a holdup of some sort at the chemist down arndale and were millions of cop cars. Got pulled over by Hanson rd
by 2 old dudes in a police Toyota Landcruiser. Got done for spacers on the rear. Not happy about it since all i was doing was driving but yeah ..... Anyone
have a stock R32 steering wheel lying around??
Yeah Steve, i have been TOLD were going on Saturdays cruise...lol. Send me the details on PM or sms or something mate!
Hmmm i wonder what else i could do when iget my tax cheque back........ :D
Not what you think baby... lol!!
sorry to hear Min
Amanda has he taken the top off the brake fluid reservoir that will help release pressure
is there a certain way of pushing the brake cylinder to put the new pads in?
coz my dads having a bit of trouble and yeah
Yeah it sucks but everyone is lending a hand which reduces my anger by alot! Adrian is helping with wheels and suspension which ive already collected!
(Cheers bro :D) Luke enr34 is going to lend me stock 32 steering wheel :) and yeah i might be getting a stock uncut front bar from another friend!
I am slightly worried about my exhaust though, is there anyway of quietening the exhaust?
You have to squeeze the caliper pistons back into the caliper either using a proper tool, a G clamp or two screw drivers....
MIN, a baffle plate between the cat flanges will do the trick.
Edited by Ryanrb25
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
