how you feeling today Luke,
wanna come on that cruise if you can get a lift to the meeting point you can come in my car still
ah well off to everlast mufflers to fit the other rear turbo brake line and my awd shaft
Still feeling quite under the weather Steve, would love to come but don't think I'd like to risk out being out that long the way that I feel. Thanks for the offer though! Hopefully once all this Regency bullshit is aside, I can FINALLY get my turbos, whack them on and go on an ohhh so sweet cruise with you all :D
what for? you have a handbrake dont you :bunny:
hahaha yes i do!
wouldn't you need R33 callipers too
oh and i have rotors
i dont know wat i need?? i need a full r33 front brake setup yeh?
adrian, When you change your brakes, ill buy your brakes off you for the 31.
keep that in mind!!!
done ryan! there all yours!
Trying to get Adrian's standard struts in but i cant seem to get the front ones in since the hub does not move down any further!! Adrian has already suggested i use spring
compressors to compress the spring --> fit it then loosen it. Would this work and who has one!!!
Cheers
-Min
good cruise!! AGAIN..
had a visit from 6coppers at the last meet point but kel talked her way through it and they were fine! asked a few Q's checked rego.. all sweet...
cruises like this are starting to give SAU a better name with the police!
well done again kel now weres the pics!!
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
    • Yeah you can. Cable tie the gauge to a windscreen wiper, or run it into the car and hold it with one hand, or have the neighbour's kid run alongside and tell you what it says.
    • I've never understood why this bothers people. Surely you'd be looking at a T3 flanged Garrett style thing, rather than a TD? You're unlikely to push a +T hard enough to need that much fuel. If you're not starting with most of the things you need to do that (ie, the bloody ECU!), you're better off just going Haltech/Link. You wil hate life a lot less. No. Just no. Just turbo it as is.
    • Have you noticed if the squeak changes with temperature or after driving in the rain?
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
