Just got back from watching The Dark Knight - what an awesome movie I highly recommend everyone go watch it :)
Yep just got back from watching it at the drive in. Fkn unreal. Ledger was awesome but the whole movie was pretty good, it unravelled quite nicely. Bring on Batman 3
-D
there's actually a thread for changing your user name somewhere, you just gota post what you want it changed to and when a mod gets time he can change it for you.
don't think they like making regular changes so choose wisely :) and wait for people to ask who the hell are you
hahaha so how many times have u changed yours Dan?
i was just wondering how long it takes to send out letters within the state? because i'm expecting 2 group certificates and i already recieved one but the other one has yet to come and they were both sent on the same day!
UNfkingBELIEVEABLE
SO I killed the cressida right, drove over 10kays with the needle on H, had the rattle of death going the whole time and also managed to cook the oil in it.
I topped up the oil/coolant today, turned the key and after a few lazy chugs, she fires up and settles to a reasonably good idle, given the previous abuse. I also drove it a further few kays with not a single problem (it hesitated slightly when moving off from a standstill on a steep hill).
I just can't fathom how it could take so much abuse and still run and drive like nothing happened. Fking 7M is damn near unbrakeable :)
UNfkingBELIEVEABLE
haha nice!
Ask Jeff from The Speed Lab how his rb20 is still running. Abuse and neglect to absolute maximum lol.
lol, it is slow when i have the missus in the car :D
she keeps me in line ha ha
I get my missus in the car and its slow.
I get her on the bike and she wants fast. :)
But too wet for the bike :P
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
