When I first bought the R32 going on 8years ago the coolant temp sensor was dicky.. First summer engine temp went from 1/4 to half. I was wondering why the car would get really sluggy and on occasions stall and then not start until it would cool. Water would constantly blow out of the overflow.
Summer past; replaced the coolant temp sensor to realise it was constantly driving around on H. Maxed out the gauge. :S
It went on to clock another 100,000km's. :bunny:
:/ unkown engine cruelty :P
yours revs that hard? :O
mine hits limiter at 6900....
i want a 26 :(
RB20 ftw, I've seen 8500rpm on many occaisions (when I bother to look at the tacho mid slide). Another 100 or so and it hits the limiter, my old AE86 didn't even rev that hard :bunny:
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
