WOOHOOO i got email notifications today
i reckon that would look great on Luke_ENR34's car :P:cool:
luke this is for u!
http://www.skylinesaustralia.com/forums/R3...&hl=r34+gtr
ALSO LOOK IN THE HOODIE THREAD TO C ABOUT UPDATES!
PPL WHO HAVENT PAID ARE GONNA MISS Out!
just a quick tip for all
DO NOT GET A 1ST YEAR APPRENTICE MECH TO ATTEMPT TO INSTALL YOUR NEW ROTORS AND PADS!
couldnt get the new pads over the new rotor, in attempting to open the calliper to fit over the rotor with new pads
he broke the fluid line.... :P
so i learnt my lesson, im just gonna pay a proffesional.
should have done that in the first place :cool:
i had my 1st appointment yesterday, i'm gonna be getting jabbed heaps
freakin blood tests, in 1 day i have to have it done 3times :cool:
i get my 1st ultrasound in 4wks, coz according to them i'm 8wks
so i just jumped 2wks LOL
i found out that the people the dad works with offered to give me alcohol
so i do miscarrage, which is nasty so grrr to them
he had every thing but a g clamp, to open the calliper.....
im just gonna send it to abs, let them deal with it.......
hopefully they can find another line for it......... :cool:
Edited by craig R33
hahahaa cheers for pm
Craig ABS make the lines up them selves so shouldn't be too hard
edit
when are you going to have your front wheels off again i would like to see the line assembly and stuff as i brought a braided line kit and it isnt right for my setup :cool:
Craig, installing rotors and pads are a peice of piss, if a first year mechanic can't do it I think he needs to re-evaluate his chosen profession cos he's obviously f**king useless...
Steve, when we get a moment, if those lines do fit my R, I'll take em off your hands. That still leaves us with the problem of sorting yours out however :cool: I guess if worse comes to worse we can take pics of yours and send them away to the group buy bloke then he can sort it out, sound good?
yeah Luke the GB bloke gave me the email to BrakeWest and they have already replied i was a little too late to send pictures off
ive been thinking that maybe my front lines aren't 100% turbo spec. but that doesnt discount that the rears don't fit also hence asking when Craig will have his wheel off next to have a look at his lines and cross-reference with mine
Needing to get both headlights and high beams, I know the best for headlights is 6000 thanx to steve but wondering what to get for the high beams and were??? Help please I'm having to drive around at night with some dodgy ass high's as normal 1 blew
a guy @ my work has these and they look pretty good im going to get a pair for my high beams and get the relay trick done
120192.jpg<<Click
NOTE R33,34 use H1 not sure what R32 use it is written on top of your headlights
he broke the fluid line.... :(
as heslo said its a piece of piss guy must have been a bit of a muppit! i would have been happy to do em for ya!
good luck getting the busted line sorted!
on another note.. still got my job :P havnt been fired yet haha! 2 weeks paid trial over and now im workin 6 days a week!
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
