Well after 3 weeks of shopping and 2 false starts, we've found a fully renovated house with huge back yard. We went and put a deposit on a pool for it today :)
Yeah, I've got a condition of the sale subject to building inspection. Settlement is due by 28 August, with a view to moving it closer ... all up to the bank really. Due to my area of work and study, I know a few people to help out in the inspection and additions, including the planned house extension.
Something like this ...
We were hoping to keep the current house as an investment property. But decided just to upgrade and move on, rather than dedicate ourselves to two properties. We start paying on the new mortgage, once our current place is sold (or in 6 months, whichever comes first).
I wonder if I could draw that in MS Paint? :P
But, do you use Autocad to draw that kind of stuff?
the assesor from my insurance company is coming out to asses me car today..im preparing myself for a write off :D ...but im gonna see how much i can buy it back for and strip it and sell it for parts and what not and then gonna start looking for an R34..but just a GT-V as getting a GTT the insurance will kill me..but oh wells hopefully in a year or two i'll upgrade to something better :D
i'll be coming around in summer so i can keep cool in your pool ;) lol
Ha! By the time summer comes around, you'll be as large as a whale (in a good way ;)).
I wonder if I could draw that in MS Paint? ;)
You could prob knock up something like this in MS Paint, but AutoCAD allows the use of layers and measuring tools, amongst many other things.
The plan has developed alot since I began the draft. Rooms have been moved and a few walls of the original house will be knocked down and removed to make for an open plan kitchen/dining area.
Settlement is around the 28th August. Pool and garage will be in and erected by September :D And house extension begins early next year. Need to remove two trees and a Hills hoist :D
haha Old Skool is cool! :D
Yep they are agressive your right so need to be set up correctly and wanting big power before you go for that style I reckon..
I use a two catch can system with overfilled oil by a litre and half (still do this even tho I have baffled the sump). I use the just jap enclosed catch can mounted on top of my head and then the breathers going to another catch can that sits near the air filters which goes to atesmophere. Mine did used to spew oil out oil even with the restrictor in when I pushed it hard around the track after about 4 laps. So we went to this system and has been great ever since, dont have any extra pressure from what I know of cause basically it's just circularting. But I dont have any oil problem's when using it for street use only on the track.
Most GTR's that I have come across that push the car hard and only have atemospheric catch cans will fill them up and spew out oil. Can I ask what you mean by hidden breathers? dumping to the ground?
hey Jess,
Have you got any pics at different angles of your catch can system & piping for it?
I've bought the unit below from Darron at Just Jap.....it has a breather hole underneath that has a tuble that extends up to almost the top part of the can with a hidden baffle inside.......bit hard to explain. Doing it this way cause cops don't like exposed breather or anything that even resembles atmospheric.
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
