lol at the valve cap problems! iv actually had some re apear on my car after a few months lol,they must have liked the new ones i put on there better lol.its just about always the really young kids that do it tho i recon.
im a desk jokey at telstra atm,only been here for a few weeks tho.i was at autobarn before this.im just happy that i get a chair to sit on all day insted of standing up for 8 hours a day lol.
cheers cubes - hows the family?!
yeah just retuning after the hiflow 617cfm Random Technology cat converter install a month ago - should have fixed the massive boost drop issue nicely
everything else is done, nicely and not too expensive. will handle 16psi daily no issues
getting the rocker cover gasket, attessa oring & another leak fixed also
hit the gas with my mum in the stag yesterday on the way to a Pain clinic appointment, pushed her back in the seat lol and stopped her chatter (for a second hahaha)
then at the lights hit the stoppies, she actually commented wow it goes really nice (too low, too bumpy, but nice nonetheless lol)
cant afford, really, to drop in the injectors this time round. if anyone wants them they can, but next service perhaps...... :P
its the 8/8/08 today!
Don't pat a black cat! Don't walk under a ladder! Don't... oh hang on... that's Friday the 13th, hey!
Haha
How many times do people write hahaha or lol or lmao... but they're not actually laughing? 80% of the time I'm not actually hahaing when I write haha! :P
gettin there for 3 ish charmaine.
Ahh yeah got ya :P
hahaha... i did laugh a little! does that count?
Haha i may not laugh when i type haha or lol....well sometimes i do. but usually i just smile :D
Ahh yeah got ya :P
Haha i may not laugh when i type haha or lol....well sometimes i do. but usually i just smile :P
I just noticed your gallery link in your sig, I just took a quick squiz... and gee!! You've got some amazing pictures!! They're awesome!! very nice work there.
I used to love photography, but ended up dropping it in year 12 :D
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
