Anyone know how much those battery clamps are (the one at the end of the cable, not the one to hold the battery down)?
I got a new battery for the 32 today but the negative clamp is too small for the terminal.
they are around 5 bux each by memory, and easily available from any auto shop.... :laugh:
cheers
Isaac
sorry NEG geeks dont go near that crap :wub:
I've been myspacin... :laugh: (geek i know) lol!
yeah if you not in with them i guess your out and all your shit gets flamed or banned
ohhhhh......they are a different breed over there mate lol
oh yeah quality thread
ha ha ha n.s at there finest >click ere<
but make sure you wear your hockey kit
Haha i know! Twas good, but didn't really get to have a chat with any of yous which sucked.
Next Villi's meet...if im not playing hockey i'll rock up in my fully sick Laser haha. I only got 2 or 3 games left of the season i think.
thankyou Madaz :D your welcome :P
U better!! run away taking photos of damos car... then left without saying bye.... RUDe hahahaha...
well this is good... post counts again.... here comes 2,000...
and sau msn group last night FTW!!!
welcome aboard IZZMO fellow 33 4door driver :D 1997 too nice
cheers guys:) i'm not really a post whore though so i wont be posting up on stuff unless its necessary lol... good to be on here none the less, Loving the new 33, ill get some pics up soon:)
i found this interesting...
Who posted in: The Sa Wasteland
Poster Posts
Madaz 844
rad32 488
Damo_R34 462
craig R33 362
Ryanrb25 256
heslo 231
SLED 205
cruzin33 192
Matty 31 191
RubyRS4 179
Hotwire 171
Luke_ENR34 169
DSTROY 166
Deluxe 162
R31 drift pig 161
Cubes 153
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
