while your doing that might as well slap a turbo on it :)
You'll need to remove the head if thats the case. Might as well throw a gasket kit at it while you're there, just to be sure. Drop the sump and replace the con bearings while you're there ... hell, re-ring it too. Check for abnormal wear and tear.
Best to spend an extra day and $300 freshening up the motor, just to be sure.
I did it will all my engines I picked up for cheap. :D
edit: oh, while the head is off, remove the valves and clean them up too.
your curve Joel from like 95 is like hold on and enjoy the ride :D
For Rad33 with his new rb25det on the way.. Get an rb30 under it. :P
RB25det vct head FTW for bottom end. :D
AL's motor is running the same GT3076 .82 on an rb30det but with a nice exhaust and inlet manifold with slightly smaller cams. The VCT has picked up some nice low end power peak power appears to be made around 7000rpm.
Now for mine.. :P 15.5psi that can be seen and the last tune at 19.5psi through the mid that tails off to 17psi causing top end to flatten out. The 2" fmic piping is causing issues up top as well as the wastegate flap being blown open.
Mine makes its peak around 6000rpm. Will play with the adj. cam gears to shift that to approx 6500rpm. :D
lol we could of told you that cars never miss behave once you get them to the mechanics - PM send about AFM's
So when the mechanics drive my car it doesnt shit itself?????????? FFS!
so where does that leave me? high and dry.
the only thing i can do is.... what for it to happen again and make sure it happens at the mechanics?
ill have to try and clean out the AFMs and check for damage.
Damo :D
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
