sorry to hear on both counts
SS, yea it's a commdore, but they still my friends :(
ok guys looks like we wont hear from Damo and Adrian tonight and anyone else that first posted today from work
SAU atm is only allowing 1 IP per user im hopeing this is fixed very soon as all of us post from multiple ip's
Wrong about the IP's Steve, now posting from Kersbrook and all is well, must be just you :( Probably someone telling you to stop posting at work and actually work! :D:(
On a more serious note, cheers for the O2 sensors, lets hope they work!
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
