LOL my "verbal bashing" was quite well deserved.
The bastard hijacked my personal photography thread in the photography section on SAU. And randomly posted HIS photos in MY thread...for MY photos only.
Im in a mood atm, where if he did it again i would be hell like :D:):(:domokun::domokun::domokun::domokun:
I think you get my point :angry:
just f**kin chill out aye
NICE dont like the VS bar im over that
hahahah ryan havnt heard of chloroform since high school ... um btw you would knbow of or be after a thermostat for a R31 brand new from nissan :D
+1
missed teh fulley sic uleh's :) is it on you tube yet
no, thanks anyway steve, they are quite expensive as far as thermostats go lol
It always helps to have a bus driver friend.
Instead of dropping me off at Marion Centre and then me having to wait 20 minutes for my bus home, he drove me to my bus stop a few stops down on his way back to depot. Stoked :D
so thats what you do in your parents astra is it angerman. make friends with bus drivers...
My car has been mis-firing inconsistently for the last week
As in some days it will run beautiful for an hour then mis fire for a while then clear itself up and run fine again!
I ran a couple bottles of injector cleaner through it, didnt really seem to make much difference at all.
Any suggestions?
Really wanna fix this tomoro arvo if possible, really starting to shit me to tears, stalled it just before the intersection as it 'randomly' started to mis fire again today
