yea good tools aren't cheap, i lashed out 5 hungy today on whats not even third of a tool kit yet....well worth getting quality tho.
My brother only buys Snap-on, his kit must be worth 20k by now, but they are good quality and will be replaced for free (without questions) if they ever break (try getting that service with sidchrome)
Im not a mechanic by trade so havent gone as overboard, but I have found Craftsman tools (from Sears in the USA) to be well priced and good quality.
funny you say that mate, cos im a fitter and turner and tools are my life. use them every day regardless of what it is...Ive tried most tools but I buy nothing but sidchrome and have had a couple of things break over the last few years only by force lol and they replaced without any hassle at all. Lifetime guarantee. KingChrome is also very good. Agreed Snap-on would be the best tho.
Edited by Ryanrb25
ruby did really well today at the track some guy did a spectacular flip lol well not really funny but yeah
pheobie wont be on here anymore cause i saw her last night at bp west tce and i told her that she is to stay off sau and a fair few other things, nene stopped me from punching her face in but yeah lol very shit night last night because of a person but thats a story for another day
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
