captain thead just left, he had to drill the f**ker out.
cost me 90 bucks, but atleast its out...
all this so the car can go PSHHHHHTTTT TTTT TTTT TTT TTTFFF
bloody turbos over rated mofos
oh not to mention the coolent i have to replace from removing the turbo, just
to get to this stupid stud... ffs
oh well, time to start putting it back together
ruby that nearly made me cry :P
actually makes me alot more thankful that i didnt wreck my 32 like that and that its getting fixed...fk i miss it tho :)
btw how the fook did that 33 gtr end up that high up in a tree????
Edited by vinnie32GTS4
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
