they do make 32 shells ive seen themm they fit a bit tight on the drift rc's though wheels hang out a bit outa the guards but who's wheels dont :blink:
i seen it at the hobby habit where they do the rc drifts. comes in GTR style only but the wing is seperate so easy enough to make it look more like yours.
kye has 1 of his own car.
also while im hear could mods please change rad32's name to
RAD MOBILE :) come on everyone agrees
Edited by Inline 6
im also keen for different work. Been at current job for 4 years, think its time for a change. DOnt wanna go earn less money though, so if anyone knows o a decent job going at over $19/hr let me know :(
pitty they dont make 32's!!!! :(
HPI make them, iv got the r32 gtr and r34gtt shell both are 200mm bodys so they will fit any 1/10th scale also yokomo make light brackets for the r34 so you can run L.E.Ds (D1 Flash kit)
These are what iv just bought from ebay
http://au.youtube.com/watch?v=hsL8Rf0rQBA
really dont care , something that isnt rediculous like child care , thats all i can find
i just need something to give me an income
head down to PEER. theyre always hiring.
im also keen for different work. Been at current job for 4 years, think its time for a change. DOnt wanna go earn less money though, so if anyone knows o a decent job going at over $19/hr let me know :cool:
same here, ive only been at the current job for 2 years, but never having weekends and all that takes its toll fair quick.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
